I bought a box of small led lights labeled “rock lights”. I installed them as reverse lights and because I had an extra, an interior dome light. I am powering these lights with that Orion 12v converter. When running the wire I kept checking my circuits with a 12v battery charger to make sure the lights still lit up. I bought 16 gauge wire.
Now I’m done, and all My circuits all work great when powered by the battery charger. They don’t work when I power them off the truck. My volt meter reads 13.70ish when I test the battery charger AND the trucks power. But when I connect the truck power to my light circuit, voltage drops to ~8 volts. And I have no idea why????
Here’s some pictures. You’ll see how bright the lights are when powered by the battery charger and how dim they are when powered by the truck. What would cause a big voltage drop like that? And why would it happen depending on the power supply???
