Tire suddenly loosing air
ramdough
1,729
Austin, Texas
I did a longer road trip 2 hours each way. The next week one of my better tires started losing air.
I looked for nails and did not find one. CTIS does not work yet. Over 2 weeks one tire goes flat
What is a likely culprit for a tire that used to be really good tire?
CTIS valve? O-ring? Look better for nails?
gringeltaube
Staff Member
2,520
Montevideo/Uruguay
In a cup, with a paint brush, make some good, stable foam with water + kitchen soap and apply around valve stem and other suspicious areas.
Check for bubbles growing...
Ronmar
7,430
Port angeles wa
Remove the banjo fitting where the larger CTIS hose connects to the hollow wheel stud. Put the banjo in a plastic bag or rubber glove and seal it to the hose with tape. If the glove inflates like a balloon, it is the CTIS wheel valve leaking. Not uncommon, put a jack stand under the axle and let the air out of the tire with the Schrader on the wheel valve, then remove the screws that hold the wheel valve cover on. There is a spring and a rubber diaphragm. On the inside center of the diaphragm you will see where it seals over the hole that feeds on to the tire. Either the diaphragm is damaged or there is dirt/corrosion around that center hole keeping it from sealing.
ramdough
1,729
Austin, Texas
Just so I am not an idiot…..
The drivers side lug nuts are LH thread, the passenger side are RH thread….. but all banjo bolts are RH thread….Correct?
