Valor
- 202
- 43
- Apple Valley, Ca.
This is where I have it on my truck and on countless other motors. Keep it to a max of 1200F sustained and you will be good to go! I suggest using a 1/8" NPT probe.Right there where I marked in red is the proper location. In the center between the two halves is solid so don’t get into that. This will give a reading on the rear 3 cylinders which run a touch hotter than the front 3.
I used isspro analogs.What style pyro are ya’ll using, analog or digital?
Several ways. Some say do it with the engine running so it blows the chips out. Some say use a vacuum and suck the chips while drilling and tapping. Some say pack the flutes with grease to make the chips stick to the grease and wipe frequently.Question about this, I know I'm bumping an old-thread. How does this work if your engine has a turbo? How do you stop the metal shavings from the drilling and tapping from going down and into the turbo?
I used a large shop vac while drilling and tapping. Once I was about to break through the manifold, I started the engine up and finished the hole. I also used the shop vac to suck out anything from the hole/manifold. Ive done multiple trucks this way and never had a problem.Question about this, I know I'm bumping an old-thread. How does this work if your engine has a turbo? How do you stop the metal shavings from the drilling and tapping from going down and into the turbo?
That's a really good idea, thanks for the hint. Did your EGT probe come with a tap? Or are they 1/8"NPT? Just trying to get prepared. What gauge did you go with too? Still shopping around for that and the probe...I used a large shop vac while drilling and tapping. Once I was about to break through the manifold, I started the engine up and finished the hole. I also used the shop vac to suck out anything from the hole/manifold. Ive done multiple trucks this way and never had a problem.
I use a 3 in one gloshift dial style boost gauge with a digital egt reading and digital engine temp reading. Mounted on the A pillar on eye level. The new model of gloshift gauges can change color depending on the amount of heat you are producing so you dont have to glance over as much you can see the color out of your periferal vision.That's a really good idea, thanks for the hint. Did your EGT probe come with a tap? Or are they 1/8"NPT? Just trying to get prepared. What gauge did you go with too? Still shopping around for that and the probe...
