- 218
- 84
- 28
- Rushville, IN
My rear tires have a bit of an inward camber to them so I thought I'd try removing some shims since I just put on some new tires. Is there a trick to getting that big bolt out? The nuts came off pretty easy but those bolts aren't budging. Any tricks you all have used? I'm about out of ideas, they pry bar isn't budging them either.
Speaking of shims, My M998 had one thick shim, one thin shim and then one that has 4 holes vs slots. I'm not sure if that is considered a shim or not? I don't carry any additional weight, any thoughts on what shims I'd need to remove to take out the camber to save me some trial and error?
