Lothar
- 661
- 93
- North Arkansas
I have been replacing wiring and cleaning up a newly acquired M1008. The glowplug system was not operating correctly when I bought the truck. I can tell it was once a well loved truck before a more recent, less talented owner took over and began "fixing" problems. I recently completed replacing all the wiring I found to be spliced up, melted, or otherwise unserviceable. Also replaced the GP relay, glowplugs and temp sensor.
I verified the resistors are working and correct voltage is reaching the new glowplugs when key is turned on. Turning key on, the wait light turns on but only 1 or 2 seconds. The truck fires up and idles but the wait light then will begin turning on and off with a noticeable draw (observed by battery charging meter and audible cycling of GP relay) on the system when the light is off.
This does not quit cycling once truck is warmed up.
I assumed this is a faulty GP card and ordered a new card from hillbilly wizard. My question or questions are, am I on track and is there another possibility that I am not even considering (like improperly wired card)? I appreciate any advice here. This truck is to be the first step in building my new, home based small business and it is taking longer than I anticipated to bring it up to a reliable condition.
Probably unnecessary but I know pics are everything so I will just dump a few before and after here.
