majkowskid
- 36
- 18
- The Great State of Texas
good evening everyone... a little background. my brother sold me his 419 that he had sitting for 7-8 years. around 60 miles on it and VERY low run hours. like 15 hours, seriously.
when i went to pick it up, it started right up after fixing a wire rats got to. i have been running fuel through it at my ranch and put around 30 miles on it just pushing brush piles. i was going to remove a boom cylinder this weekend to reseal, but the mog died on me when moving it around. it will crank, and idle occassionally VERY rough. a little shot of starting fluid and the engine runs great for 2 seconds. it's quite obviously starving for fuel. i decided to drain all the old fuel out, and put new in. checked the fuel strainer and it was clean. i have had fuel filters ordered for a couple weeks but they aren't here yet but i decided to check them anyways. the filters have a stamped date of 09-08-52 on them. seriously! they seem ok honestly.. but are obviously old. i put them back in, and blew low pressure air through the fuel lines from the tank. I then used the primer to reprime which was a helluva ordeal. i was pumping that stock primer pump for like 30 min. it started and ran like it was aobut to die for 5 min. i just let it sit there and try to idle, and all of a sudden it cleared up. i drove it for 2-3 min, and then it just lost power and died again. i can't get it to start now. i tried to reprime the filters and no fuel would come out after 10 min of pumping.
1. i'm waiting on the new filters and seals and will put them in when they arrive.
2. i ordered the new design primer from expedition imports.
could it be the actual primer assembly? i'm praying it's not the actual fuel pump assembly as it looks pricey.
