- 630
- 942
- 93
- La Crosse, WI
Well checked under the PDP and found a lot of power distribution stud nuts finger tight. Also some corrosion to clean off. Found paint under the chassis ground stud as well. Fixed everything but still same situation with ABS. The "ignition voltage" is still reading under the "battery voltage" (I've seen it anywhere from matching to about 2V low) and the "ABS brake" still shows "N/A" which is different than others I've seen.
Still more work to do cleaning up in the switch box next to the battery and pull out the LBCD and clean it up.
Haven't probed voltage at the ABS computer under load yet either.
Update: checked voltages at pins 1, 2 between gnd pins 11,12 and also chassis gnd. They were all less than .1v difference from what wabco software reported as "ignition voltage". I can only assume it's getting battery voltage reading from the bus?
Still have some more voltage I can check but am loosing faith in finding the issue. Almost seems like a config issue with the ABS computer....your abs light is on and you say no abs is available but don't give me any error codes and all wheels read fine and modulators are all good too ...wtf
