- 231
- 764
- 93
- USA Indiana
Hi everyone I’m again working on my Lmtv. The problem of the day is the transfer case doesn’t engage 50/50
when mode is selected. However it does when I select 1st gear. I checked the scavenging screen, looked real good.
A few bits of plastics or gasket material. I am going to check c7 clutch pressure in both cases. If I lack c7 pressure
in mode I’m going to need some more info. Is the c7 solenoid in the transfer case or on the valve body? I have
multi meters and lab scope to check voltage/waveform. What should I be seeing in mode? Which pins or
terminals? Thanks. Mike
