M1008 Timing chain replacement
Finnegan1008
164
Connecticut
I will soon be changing the water pump on my m1008. I figure when I have front of the motor apart I should do the timing chain. Would you all recommend this?
If so what TM outlines the procedure? I can’t seem to find it through my own research or searching the forum.
Is there anything else I should check or replace while I’m in there?
adf5565
677
Tioga, PA
Sections 3-10/11 and 3-21/22 of TM 9-2320-289-34 will have what you need, and yes the front of the oil pan does bolt to the crankcase cover.
You can replace the water pump without removing the crank case cover. Section 3-48
nyoffroad
687
Rochester NY
The water pump is minor surgery. The timing chain is major surgery. Unless you have oil leaks from the front of the pan or balancer front seal. I suggest leaving the timing cover in place.
Yeah , unless the engine is real high milage there's no real need to replace the chain and if thats the case then it needs a complete rebuild.
Barrman
1,730
Giddings, Texas
I didn’t mention a small ledge you do have to mess with because the TM was linked already. You will not be removing the water pump from the engine. You will be removing the water pump backing plate that happens to have the water pump attached. Then you have to swap the backing plate over to the new water pump. Then, install the backing plate back on the engine.
The TM says to use a gasket between the water pump and backing plate. Then, the TM says to use anerobic sealer between the plate and the timing cover. I ordered the special sealer for my first water pump job, had a slight leak when I did a pressure test with a dry system, took it all apart again and still had a very small leak. The 3rd time I used Right stuff between the pump and backing plate and between the plate and the timing cover. Sealed system!
That is how I have done every water pump job since and no leaks on them either. Do as you wish, just passing on my ham handed issues.
Finnegan1008
164
Connecticut
I appreciate the advice, seems like Right stuff is the only way to go with pretty much anything you don't want to leak on these vehicles
