Oil Leak Around Oil Filter
Hummer Guy
807
United States Louisiana
I've been having a small oil leak around the oil filters for the pass several months or so, it only leaks when the truck warm up. I thought it was the gasket under the oil filter housing, so I changed them and torqued it down, it wasn't, it still has the same leak after about 20-30 minutes of the truck warming up. I heard of people saying the FDC leaks but the leak I have is oil, not fuel at all.
Have you guys had a oil leak around this area? If so, where was it, the common place I hear is the gasket under the spin on filter which I checked and the FDC.
(I have the spin on oil filter)
Hummer Guy
807
One of my guesses is that a clog breather can be causing the leak but the only breather that I know is the crankcase hose on the passenger side which seems to be releasing off the crankcase pressure properly
ToddJK
4,518
Sparta, MI
About to do the same thing honestly, I wonder would gasket maker do any difference
You can try the black adhesive permatex to see if that solves the problem, but I would only apply a small bead all the way around the very outer edge of the filter base so none of it makes it under the adapter. If a piece came loose, that could clog something and make a small issue into a big issue.
