coachgeo
- 3,404
- North of Cincy OH
>M1078 suspension is burdened via heavy loads occasionally.. while the M10xx is always burdened with a heavy load when the 1079box is on it.Yep that is correct. If I were to load my enclosure enough then I would be over the rated weight for the original M1078 suspension. I should still be within the ratings of the M1078 suspension as it sits today and after adding a couple of things inside.
>Sometimes there is wisdom to not second guess the design engineers... especially when the design added expense and not reduced it.
Just somethings to go hmmmmm??? about when contemplating suspension and stress on chassis.
