MK23 transfer case oil?
airdrillpitcrew
Ritzville WA
Hello everybody. Im in the middle of a complete service of a 2001 MK23 that our farm has turned into a brush fire truck. Im curious what everyone is doing for the oil in the transfer case. So far, what Im told is this unit takes 6 qts of 40w non detergent. Is this true, if so, what is everyone doing for oil in these. Truthfully, 6 qts doesnt seem like much, after all, the transfercase is huge, Im concerned that the top bearings might not get enough oil. Any info would be greatly appreciated.
20,430
I pulled this from a manual
Table 23. Transfer Case.
Item Specification
Make and Model Oshkosh 30000 Series
Type Three shaft, single speed with torque proportioning
differential with manual differential
lock
Ratio 1.271 :1
Torque Split 32% Front, 68% Rear
Transfer Case 6 Qt. (5.7 L)
Oil Type OE/HD040
The transfer case incorporates a 32/68 differential. The transfer case 32/68 differential provides full time, all wheel drive, and proportions approximately 32 percent of the torque to the front axle and 68 percent of the torque to the two rear axles. The differential has an operator controlled, air actuated, drive line lock mechanism, which consists of a sliding lockout collar that locks the differential housing to the output shaft. The differential drive line lock mechanism provides increased mobility in adverse operating conditions.
Transfer Case
Check and Fill as Necessary
lubricant OEIHDO
Interval: 36/A (I)
View: Oand P
airdrillpitcrew
Ritzville WA
Item Specification
lock
Ratio 1.271 :1
Oil Type OE/HD040
Transfer Case
lubricant OEIHDO
Interval: 36/A (I)
View: Oand P
This is great, thank you. Does it say anything anywhere about requiring non detergent? I assume it might want it because of the clutch pack. I just want to confirm this before I special order more oil. Thanks a bunch
airdrillpitcrew
Ritzville WA
Item Specification
lock
Ratio 1.271 :1
Oil Type OE/HD040
Transfer Case
lubricant OEIHDO
Interval: 36/A (I)
View: Oand P
Since it appears you have the real info, any tips or info on servicing the planatery's?
IridiumRed
92
NW MO, north of KC
I just changed the transfer case fluid on my MTVR yesterday, i went and used straight weight detergent SAE 40 oil in mine. I figured the military had lots of 15w40 oil around, lord knows they use it in almost everything else on the truck... if they specced something different for the TC, there was good reason.
I was able to find that oil at local parts stores, surprised me a bit, never noticed it before. Ive used straight 30 weight a number of times for various things over the years (both detergent and non detergent depending on application). I did have to go to 2 parts stores to get full amount tho, no one place had enough.
FYI, i bought 7 quarts, which was good bc mine took about 6.3 quarts, and truck was level (actually was jacked up a few inches in front, bc changing front hub oil so needed it lifted up slightly to be able to rotate wheels to correct position). That would tilt TC up slightly, make fluid run out of fill hole slightly easier.
So, long story shorter, mine took a bit more than 6 quarts, but if you put 6 quarts in i suspect youd never notice difference. Same w using 15w40 oil....
One last thing, the TC fluid was kind of milky in appareance. Id suspect water, but there didnt seem to be any separation (water sitting at bottom, coming out first), also zero evidence of rust.... no redness at all
Now, my truck is an 03, shows 1200 miles on it (bought from GP as a runner last year), no cab / doors... AMK25), been going through changing fluids among other things. Some of the fuids, like transmission, looked new, filters had 03 dates on them so prob original.... but some of the diffs showed some water and at least some light rust (all the hubs looked good tho, no water... but there also was some evidence they had possibly been drained / refilled before). Anyways. Just some info on my truck, thought id pass along in case it helps someone else :)
hvydee
29
13
Marietta, Ga.
I agree, use what the military spec says, your post had a lot of good info in it. I’ll be changing fluids on my MTVR soon..
