EPROM’s
twisted60
250
Jupiter, Florida
Are all the eprom’s compatible in the TCM’s ? I see different years I assume different programming for shift points as trucks got heavier ? I’m just trying to learn more about the different Humvee’s.
Thanks
Mogman
9,584
Papalote, TX
Basically yes but for the later PCS TCMs which do not use a PROM.
Some are EPROMS and some are PROMS, the difference is the EPROMS can be erased using UV and re-programmed and a PROM is a one time use device, no difference to the end user.
I have some of the hex files and can erase and program them, I would like to build a library of the different files, then if I got really bored I could dig into the hex files and decipher the differences and even come up with custom shift points/DTCs etc.
The "major" differences are the NA and turbo chips and likely has more to do with the gearing than the weight, they may have also added or dropped what DTC codes would and would not light the trans light and possibly what actual perimeters set DTC codes and fixed any bugs as time went by.
twisted60
250
Jupiter, Florida
Thank you that helps me understand them better, I was confused by the dates on the chips. So a 1999 turbo chip is good for 2006 turbo but not for a 2006 non turbo and the newer TCM’s don’t have chips.
Again thanks
Coug
4,355
Olympia/WA
NEWS | July 7, 2021
HMMWV: TCM Has Replaced EPROM
HMMWV
Photo by Sgt. Kristina Truluck
Mechanics, make a note that the erasable programmable read only memory (EPROM) has been replaced by the one-piece transmission control module (TCM), which is needed to operate your unit’s HMMWVs.
If you have a HMMWV that’s NMC because it needs a 2-piece EPROM and you try to order a replacement for it, your requisition is going to be rejected.
You also don’t want to order a transmission because it won’t come with an EPROM.
Send any questions you have about ordering correct parts to the HMMWV maintenance team mailbox at:
Mogman
9,584
Papalote, TX
Again thanks
I have heard some swap them, I can't remember which way, IIRC they put a turbo chip in a NA truck and it shifts "better" in their opinion, but again I do suffer from CRS.
The later TCMs are crazy expensive compared to simply getting a refurb older style.
twisted60
250
Jupiter, Florida
Yes the new TCM’s are pricy $650 up. I’m going to try getting an old civi TCM with an eprom to just try ($250 +/-) if it works I’ll keep for a spare, if not … well I learned something
Thanks
86humv
501
Texas
The trans computer in most trucks is a GM unit with a replaceable blue chip.
The TCm-2100 series is not a GM product, and has no replaceable chip....later trucks have these.
They both will plug into the box under the seat.
twisted60
250
Jupiter, Florida
Thanks, I’ve found 2 compatible GM TCM’s used and ordered the blue chips so I’ll find out, hate to pay $650 up for a spare. I’m really just trying to learn more and investing $200 is worth it to me.
Thanks everyone.
Rick
Mogman
9,584
Papalote, TX
Thanks everyone.
Rick
You can get a refurb for about the same price
deshet
35
Virginia Beach, VA
If somebody can point me to a refurbished one for $200 that would be great.
I have a failed tcm-2100.
@twisted60 How did testing for spares work out?
I trying to figure out the most economical way ahead to get my truck on the road. Has anyone found a rebuild service that is reasonable. Is it possible to pull a unit from a GM truck and used that?
I have been told that BSE tcm609 works but the pictures look completely different.
I would appreciate any help.
Thanks
twisted60
250
Jupiter, Florida
Good day. The units I tested with the new blue EPROMs worked great. I’ve put them in 3 Humvee’s and all are working great. I’ll look for the pics and attach in next message.
deshet
35
Virginia Beach, VA
Are you saying that you were able to replace the TCM 2100 with this unit you are referring to and do you have a part number? Is this something I can go to the junkyard and grab from a GM vehicle.
I appreciate the fast response.
deshet
35
Virginia Beach, VA
I really appreciate all the effort did you have to modify your wiring harness? My connector looks completely different.
Can you tell me what website had the $17 eProm
Thanks
TOBASH
3,488
Brooklyn, NY
There are two main types of transmission controllers. The newer ones have no port for and therefore cannot accept the EEPROM chip.
please post the TCM you have
TOBASH
3,488
Brooklyn, NY
That TCM does NOT have the port for the EEPROM
ask Mogman to post a picture of his unit. It will look different
Mogman
9,584
Papalote, TX
He has a failed TCM so he is looking for the info on replacing it with the older style.
