Front lockout on M1009
Stroked66
19
Salamanca/ ny
Hi everyone,
First post, but need a little help. My 86 M1009 has an issue with a loose front lockout, the (6) cap screws are tight but the lock selector housing wobbles around quite a bit such that the o-ring cannot provide a good seal. Thanks in advance
WWRD99
1,835
York Pa
Hi everyone,
There's a snap ring that holds the inner part in the hub plus one on the end of the axle shaft.
WWRD99
1,835
York Pa
I saw those two and they both seem to be engaged properly. Thanks any other ideas?
Darn!! Was hoping that would do it! Ok...are they a brand name lockout? Like warn etc? I've run into some that were a no name brand and the guts weren't made right.
WWRD99
1,835
York Pa
They look to be the originals. Both of my CUCV’s have the same identical lockouts. .
That black spray painted ones. Ok ..my next step would be checking the big snap ring and make sure it's thick enough to hold it tight.
87cr250r
2,034
Rodeo, Ca
Got any parts for Dana 60 hubs? I need one selector and believe I need those thin washers inside. I had a king pin pull its threads which allowed the wheel to lean in and out which pulled on the axle shaft and bent up those washers. The hub still works, it just isn't right.
cucvrus
10,467
Jonestown Pennsylvania
I do have many parts for stock CUCV M1008/1028 L/O hubs. And M1009 hubs. PM me. I like to trade. IMG_0896.jpeg IMG_0895.jpeg IMG_0894.jpeg
Stroked66
19
Salamanca/ ny
I would swap another lockout into the hub and see if you have the same slop. It could be it was loose for a while and wore into the aluminum hub assembly, but that big PITA snap ring should be in place and tight. I have lots of OEM hub parts if you get in a bind. Be Safe.
Ok Guys, I will swap out that section tomorrow after checking the ring thickness. Nice to know you have a place to ask questions. I’ll keep you posted.
Stroked66
19
Salamanca/ ny
From one to another you mean. LOL Started researching the Corporate 10 info so thanks again for the "no brainer" heads-up! I did get a set of NOS lockouts from Hillbilly Wizard and that fixed the problem. With (2) M1009's I don"t mind having a complete extra set, so next I'll look into getting a set of 0-rings for the lockouts that I removed.
