Hello I have two mep 831a generators both run great . One has a fault that just started showing up. It’s the low oil pressure one. The only thing the tm says is to check the valves…… do these have an oil pressure sensor? Should I try anything else other than the valves ? Doesn’t seem like the valves have anything g to do with it ? Or do they?
