TB1. The long TB in the picture. The last 2 wires on the left side should be F1 and F2. The F1 is positive. Start the set, then apply the DC voltage to F1 and F2 momentarily. Don't get the polarity wrong.
Ok, I’ve located everything and familiar with the steps.TB1. The long TB in the picture. The last 2 wires on the left side should be F1 and F2. The F1 is positive. Start the set, then apply the DC voltage to F1 and F2 momentarily. Don't get the polarity wrong.
It is a PFR-1K, she was gummed up from sitting 15+ years but fired up without skippingOn the IP, you may have reasembled it with the plunger 180* from the alignment marks.
I worked on a 701 years ago ( same engine ) where the governor was acting all kinds of wacky and the thing would not run right... revving up, running away!
Turned out the IP had been gummed up and the owner tried to free it up and somehow got the plunger timing all out of whack such that moving the lever / rack had the opposite effect as it was supposed to.
So trying to increase fuel was actually decreasing it and when the governor tries to decrease fuel it would actually increase it, causing full throttle runaway.
If I recall correctly, the issue was that the barrel is not fixed in position in any real way.
When the pump gummed up, he fiddled with it and broke it free, but also rotated the barrel, essentially causing the timing to go out.
I'd have to go back and research again, but I found the info I needed on you tube by looking up the name of the metering pump. Bosch / Zexel PFR If I recall?
It all came down to making sure the marks were all aligned correctly.
