I will never remove it again lolI never separated the plastic desiccant cover from the inner aluminum tube. It being on the downstream side of the filter and dessicant, mine was perfectly clean down inside. The plastic core, air filter and aluminum tube came out as one assembly from the finned outer housing. I showed re-assembly in a video. Have you seen it?
.Speaking of air driers I have the new style with the replaceable cartridge. How often or how many miles should they be replaced? Realistically.
My truck maintains about 95 psi overnight. And then over a few days it will go lower. Rarely lower than 60 unless it's very cold. I keep working toward perfection but it's not an easy task. The fewer the leaks the less load on the compressor.Great info thanks guys, I traveled 14,000 miles in the last year, never had any water come out of the tanks when I drained them. As far a leaks go, after 2-3 days the system leaks down for the most part.
Not bad enough to dig into the culprit. In my opinion.
