williamh
- 629
- 93
- SanDiego Ca.
I gotta emp proof vehicle. It’s a M35. Mechanical pump and takes all types of fuel. As long as you can get the motor to spin …. You’re off to ????
You’ll never go thirsty in a HMMWV. Water always finds its way in.At least the HMMWVs have a lot of protection from bio hazzards. With their hermetically sealed doors and bio filtered vents we can feel secure. Only problem I've found as you need to crack a window or the air starts to run out.
You can always take 2 batteries and slap the leads across the solenoid terminals to get the starter spinning. Saw my uncle do that a few times on the JD diesel 730. The brain is truly EMP proof but it is prone to faulty inputs🫠I gotta emp proof vehicle. It’s a M35. Mechanical pump and takes all types of fuel. As long as you can get the motor to spin …. You’re off to ????
