Myrtleman
- 6
- 3
- South Carolina
Hi all. Changed out my fuel filter in my 1097A2 yesterday and used procedure outlined in the technical manual. I used the bleeder screw on top to purge air. Today I wanted to be super sure that all the air was out so I used a vampire pump at the fuel filter outlet on top of the housing to draw out fuel. I reconnected the fuel line, started the truck, and it stumbled for a second. I gave it some throttle, it recovered and is running really smoothly. However I noticed that all of a sudden, my fuel gauge is reading half the amount of fuel that it was reading prior to this procedure. I assume that the vacuum affected the sending unit in some way? As a sidenote, I know these are 25 gallon tanks, however after putting in 10 gallons of fresh diesel in my empty tank a few days ago, it’s only reading 1/4 tank. Is this normal? Not sure if the sending unit was on its way out and I finished it off with the vacuum pump? Thanks in advance for your help.
