Myrtleman
- 6
- 3
- South Carolina
I finally got around to installing a Schwend Waterjet keyed ignition today (great concept and product) and while I was at it, I was trying to decipher whether or not to remove a welding switch on my dash. Apparently this was a contact Truck with a welder in the back. The wire leads are labeled number 69 and number 70 and they feed up through the firewall and connect to where I have included a picture (time delay module). Excuse my ignorance for not knowing what these parts are called but this is my first rig and I’m learning every day. Is it safe for me to remove the switch and the leads and then just connect those two plugs together that the switch is currently hooked up to under the hood that I have pictured? I circled where it exits the firewall and I also circled where the leads are connected in the photo. I also included a photo of the back of the switch and the labeled wire leads under the dash. Thanks for your help
