vanjosh
- 1
- 3
- Santa Cruz, Calif.
Hey there, I'm working on an 1995 M1078 truck with an Allison MD3070 transmission and having some trouble. First off the LBCD (polarity distribution box) has a smallish wire with ring terminal im trying to figure out which polarity to connect it to. I didn't make a mark of whether it was from the 12 V load or 24 load side. Does anyone have a diagram of what is connected to the LBCD unit by default? They way I have it now is:
Stud 1: 12 V battery on the first stud
Stud 2: 12 volt alternator/12 V distribution to PDP (fuses,relays, etc)
Stud 3: 24 V alternator wire/24 volt distribution to PDP
Stud 4: 24 V battery
then loos wire im unsure of. Can anyone give any guidance?
Next problem, when I reconnected everything the truck fires up but it gives error codes that give it the no shift issue. The codes are the following:
D1 45 22
D1 44 22
D1 44 14
D1 22 16
D1 44 13
All of these are codes for transmission solenoids, and the 22 16 code is an output shaft reliability test. Does the transmission have anything to do with the LBCD connections? I am able to read and clear the codes but they keep coming back. Is there anything I'm missing?
D1 45 22
D1 44 22
D1 44 14
D1 22 16
D1 44 13
