Drivetrain 101 for a 4 wheeled vehicle:
2WD = 1 driven wheel out of 2, with a 50/50 torque split left-right In that driven axle. Either wheel slipping will allow all the torque to escape there.
AWD = 1 driven wheel out of 4. Torque is biased fore-aft 30/70, and 50/50 left to right in each axle, but If any one wheel of the 4 can slip/spin, 100% of the torque will escape thru that one spinning wheel. put one wheel on a jackstand and select drive and it will happily spin away. The 70/30 torque split is pretty standard on AWD vehicles so it will tend to spin a rear wheel first for easier/safer vehicle control. If you put a front wheel up on a jack stand, and rev the engine(deliver more torque), the 70/30 split may put enough torque to the rear axle to push the truck off the front jackstand, but that front wheel is going to really spin
4WD = 2 driven wheels out of 4. 50/50 torque split in the transfer, 50/50 split in each axle, so one wheel on each axle needs to spin to let the torque escape/not move the vehicle. Add a rear locker, 3 driven wheels out of 4.
in a 6X truck, the power divider is basically another center differential between the 2nd and 3rd axle. So any torque sent to the rear two axles is divided amongst the 4 rear wheels like a 4X truck, which = 1 driven wheel out of the 6 total on the truck. Pretty common to stop moving if terrain lifts either front or rear axle high enough to spin a wheel. In mode the power divider locks like the center diff in the transfer, and you get 3 driven wheels out of 6, split 50/50 left to right… one wheel on each axle must spin to stop the truck…
