Nissan Armada Springs
coolboatguy
las vegas
Just for reference. 1097a1 with Nissan Armada springs in the front. Moog 81085, 3/4 coil cut. I put the springs in without cutting and it was too much. Have done nothing to the back. About 2.5 lift. Tires are 40's.
Perfect and nice job. I think I cut one full turn in the front but a quarter turn is negligible. You should do the rears too. It needs the rear done more than the front usually because not only is the rear lighter but the stock springs are sometime 3 times stiffer. Also the rears mounts are taller so you only cut 1/3 coil off and you can use the daystar spacer for that perfect level ride.
