msgjd
- 3,637
- upstate ny
This design of lift pump doesn't generate hardly any psi .. They are an "indirect" or "bypass" pump, for lack of a better term.. Most of the fuel gets slung aside as it spins.. When fuel level is low enough, you can hear it churn away from the impeller. If the fuel lines are restricted, this design of pump doesn't care .. No extra pressure is created.. The "excess" fuel the lines cannot take just stays in the tank as the impeller spins happily away.. Think of it as a little cooling fan on a desk or table.. Block the output of the fan with cardboard and the air just gets flung aside elsewhere.. No rise in pressure, the flow takes the path of least resistanceIf the lines are blocked with crud, wouldn't I see HIGHER pressure at the tank? I'm only seeing ~2-3 PSI
