- 29
- 28
- 18
- 32789, Florida
My throttle sticks at about 1/3 "remaining" when I let off the pedal. I have replaced the two throttle return springs...but that wasn't enough. I'm now going through para. 4-18 "Throttle Control Cable Replacement/Adjustment" procedure. Curious, before I try, if anyone has sent lubricant down the cable just above #7 in the diagram below (throttle rod from the pedal and bell crank) and had this issue fixed. The engine side doesn't seem to bind and the hand throttle is not interfering with the assembly.
