HUMMER H1
- 820
- 93
- California
I bought an ECV humvee that was sold as not runner,
I started today and runs beautifully.
However transmission doesn’t engage unless I raise the Rpm to 2000 ish
all the symptoms show no fluid, transmission pan bolts were taken off ( I assume to drain the fluid)
but the dip stick shows a little over than normal X mark,
is it possible the dip stick is not accurate?
later model 4L80e transmissions don’t have a drain plug I can’t drain and start all over,
thank you
Eric
thank you
Eric
