Pop off valve sticking, need correct term for the TMs
kendelrio
8,971
Alexandria, La
Ok all,
My pop off valve (when you build pressure it pops off) is sticking in the half open position after I build air, bleeding it slowly down.
I had this issue once before and for a temporary fix I followed the advice of @fuzzytoaster and used an extension and hammer to whack it back into place. Now it's consistently sticking, so I need to take it apart and see what's going on.
I know I could spray it with lube, but that only attracts more dirt etc, so I would like to clean it so it's "dry".
My issue is I don't know the proper term to search in the TMs. Any help?
fuzzytoaster
3,475
Fort Worth, Texas
Time for a full rebuild or replacement. There's a few options in the parts cheat sheet depending on how are you want to do with it. Here's the cheapest service kit i found with a quick google search. Ebay link
Air Dryer COMPLETE UNIT "Air Plus System"NAPA/MIDLAND/HALDEXMBI DA33110X
Upgraded dryer from MRAP Contact Member Suprman or ZiggyOHALDEXN50011K
MRAP DRYER INSTALL BRACKETNAPAMBI DQ6051
Air Dryer FILTER KIT for MRAP N50011K Haldex Dryer NAPA/MidLAND/HALDEXMBI DQ6050
Air Dryer Repair Kit for ABS HALDEX "Air Plus" NAPA MBI DQ6026
Air Dryer Purge Assembly ( plunger with o rings) (Air Plus and Purest Dryers)Napa/TruckPro/HaldexDA33115
Air Dryer Lower Rebuild Kit (Air Plus and Purest Dryers)Napa/TruckPro/Haldex
kendelrio
8,971
Alexandria, La
Air Dryer FILTER KIT for MRAP N50011K Haldex DryerNAPA/MidLAND/HALDEXMBI DQ6050
Air Dryer Repair Kit for ABS HALDEX "Air Plus"NAPAMBI DQ6026
Thank you my brother by another mother!
In the TMs, what do I look for?
98G
Former SSG
4,620
Well, it'll be the old "take it apart and put it together" method then! 😁🤣😂
Pressure protection valve opens the secondary side at 70 psi and supplies air to the wipers and horn and governor.
At 120psi the expello valve sneezes.
If the PPV fails, the sneeze never happens and you get pressure to 150psi at which point the pressure relief valve opens.
What i think you're suffering is the expello valve on the air dryer is sticking.
kendelrio
8,971
Alexandria, La
It's the one that normally sneezes at 120.
