- 1,079
- 1,156
- Basehor, KS
Since @Guyfang thinks that you have a temp sensor installed for the “diesel fired heater”, which is correctly called winterization kit and we have not had a 360 degree view of your generator with all possible doors open posted as pictures, I would suggest you do that.I can't find it then. Is it on the motor or elsewhere?
We are hundred, if not thousands of miles away from you and your generator and we do not possess crystal balls which show us the internals of your generator.
The installation of a winterization kit requires the modification of the coolant circuit and the electrical wiring.
The winterization kit has a lockout where the generator won’t crank when the pump and heater are running and then, when pump and heater are stopped, a lockout if the coolant temperature is below 120 degrees. You can start the generator but it won’t stay running.
At this point we don’t know if the entire winterization kit is still installed and or what parts where removed.
I would check all coolant hoses and radiator for sensors, pumps heaters etc
and post pictures, many many pictures
