Tie rod end threads
Enforced_Leo44
76
Parma, Italy
I want to replace the outer front tie rod ends that connect to the geared hub, but I'm not sure wether they are left or right hand threads, can anybody tell me for sure what thread direction they are? and if they are both the same direction of course
thanks in advance
Mogman
9,560
Papalote, TX
You need to check, each tie rod assembly has a right and left threaded tire rod end, one side should be right and the other left BUT the tie rods can be installed ether way so.................
Retiredwarhorses
4,176
Brentwood, Calif
thanks in advance
just buy an entire rod assy…also, make sure to buy the correct length rod for your model truck
Enforced_Leo44
76
Parma, Italy
You need to check, each tie rod assembly has a right and left threaded tire rod end, one outside should be right and the other left BUT the tie rods can be installed ether way so.................
Ah right I see, I thought that there was a “right way of installing” the assy, thanks for the heads up, will check
TOBASH
3,475
Brooklyn, NY
I can’t comment to the individual item, however, Hummer parts guy as well known within the community. You can also contact them and request information.
