Passenger Side Alternator Weirdness...
WWRD99
1,715
York Pa
Yeah, I was going to replace the connector too, just in case.
As for the hydraulics, I just replaced what was in the truck. I didn't add anything else. I don't see a filter in the TMs, so it hadn't occurred to me.
Are you suggested trying to pull out as much power steering fluid as I can, and try dextron in it? It can't hurt, I guess. If the boost has gone bad, I can't really make it any worse...
No there's no filter in them stock at all but there's a bunch out there to fit a 3/8 hose. The booster has a check valve that's almost a pencil point that if it gets stuck can either give all the pressure or take it away.
LouhiKhar
New Hampshire
Finally had a warm enough day without precipitation...
Did a flush of the hydraulic system with Dextron. Pushed about half a gallon through the system, installed in inline filter in the return line, then buttoned up the system. I forgot to take pictures...
It behaves a bit better now... But I'm still losing a lot of the hydraulic pressure when braking, one the accumulator is exhausted. I'm hoping it's just air trapped in the fluid. I did a quick bleed and ran it around town for about 10 minutes. I ran it just after the flush, and it It still has that shimmer off bubbles, so I'm hoping if I let it sit a bit, maybe a day or two, and let the air bubbles settle out, maybe it'll be better...
Everything in the system is new in the last year or so, except the steering box, which the guy I bought it from said he did in 2020... If this didn't fix it, then I may have to find a real mechanic in my area who will look at it...
I have the new connector for the alternator, but as the alternator issue doesn't keep it from running (at least so far), I'm concentrating on trying to get the hydraulics sorted out...
Always more work to do...
WWRD99
1,715
York Pa
I wonder if the ps pump pressure regulator us not working. New pumps fail.
LouhiKhar
New Hampshire
Finally got time to replace the steering pump, and...
Now the hydraulics seem fine. I opted for a new one, not reman, so it'll have a better warranty, if nothing else...
Just did a ~30 min tour around town and it stops, turns, etc. as expected. No soft brake pedal, no stiff steering... Now hopefully I'm not replacing this pump in a year...
Still getting some flashes of the ol' Gen 2 light, so that debug continues. Electrical connector is the next project, and then chasing wires...
LouhiKhar
New Hampshire
Finally got around to changing out the connector for the alternator. Not my cleanest solder job, but it works...
Still getting good voltage across the battery (high end of 14V territory, hard to tell exactly on the crummy analog multimeter). No real change in behavior. Still getting flashes and flickers of the Gen 2 light. It's getting ready to rain, so I'll have to trace wires another time.
