Here is the information off the Female connector that goes from the wiring harness into the male connector on the following lights.
The below listed connector will work on the following lights:
#1 – Round Dome Light
Intelligent Dome Light System
6220-01-556-3938
P/N 265WG0219C2A003
(Round Dome Light)
((Two male connectors 180 degrees apart on major diameter.))
#2 – Rectangular Dome Light
6220-01-556-5569
P/N 3825157C91
(Rectangular Light / with mount / Jerk and run)
((Has one male connector on opposite end of light controls))
Connector female
ITTC 1247 7524125 CA3106E10SL-3SBF80
Female connect is part of wiring harness listed below.
6150-01-568-5809
338X5
P/N 3113430C91L
HARNESS
CAGE 75059
SPE4A612M6342
DION DEFENSE GROUP
5255 FEDERAL BLVD
SAN DIEGO, CA 92105
WWW.DIONTRUCKS.COM/DION-DEFENSE
619-263-2251
URL verification on 4/4/2024 indicates domain DionTrucks.com is not a valid domain company may be out of business.
Google search 4/4/2024 indicates Permanently Closed.
PRODUCT INFORMATION
Specification: | MIL-DTL-5015 Type |
Connector Type: | Connector Circular |
Connector Style: | Plug |
Contacts, # of: | 3 |
Contact Style: | Pin |
Insert Arrangement: | 10SL-3 |
Contact Size: | 3#15S |
Insert Material: | Neoprene |
Amperage Rating: | 22A |
Operating Voltage AC V RMS Max: | 500 |
Operating Voltage DC: | 700 |
Export Class: | EAR / EAR99 |
RoHS: | No |
Weight (lbs): | 0.06596 |
Weight (g): | 29.92580 |
CA3106E10SL-3SBF80
ITT Cannon - CA-B Connector
CB 3C 3#16S SKT PLUG
RUGGED 5015 CONNECTOR FOR HARSH ENVIRONMENTS
ITT Cannon CA series MIL-DTL-5015 connectors featured a threaded coupling mechanism and are manufactured to MIL-DTL-5015 for use in very harsh environments. ITT Cannon CA Series heavy duty 5015 connectors were originally designed as aerospace components and are popular, cost-effective, rugged commercial and military connectors. Hundreds of contact layouts are available, including common 2-pin connector, 3-pin connector, 4-pin connector, 12-pin connector and 16-pin connector types. The ITT Cannon CA series is a waterproof 5015 connector that is completely sealed to withstand condensation, vibration, and flash-over.
https://www.farnell.com/datasheets/2100452.pdf
https://www.newark.com/itt-cannon/c...-SKU-Connectors-and-Cable-Connectors_TCPA-S44
Current Price on NEWARK is $44.77 ea, if I have not made a mistake.
