Where to find fuel filters for Multi Fuel M35a2
cessnapilot89
234
33
Alliance, Nebraska
Sorry for a dumb question, but where is the best place to get the fuel filters and gaskets for an AM general m35a2 with the white multi fuel engine?
Doing my first oil and filter change today and want to get the fuel filters swapped soon
19,623
Here is the Spreadsheet for locally purchased oil (and other) filters
cessnapilot89
234
33
Alliance, Nebraska
Thanks guys. Second stupid question, what is inside the filter housing on the right frame rail and is a single housing? And where would I find a replacement for that filter ?
Adrok
182
33
Rochester NY
The housing is the first ( primary ) fuel filter. The filter is shorter than the housing so it can be used as a water separator. There is a spring inside to position the filter properly.
All the NAPA filters ( that i purchased ) came with multiple size gaskets. Take your time, I had a hell of a time getting the gaskets and housing to seat properly so they will not dribble / leak.
The fuel filters are all run in series, so I set up for increasingly smaller filtration.
From Napa I used:
Primary: Wix 3511- 10 Microns- Water Separation
Secondary: Wix 3512- 10 Microns
Final: Wix 33540- 6 Microns
Cheers
cessnapilot89
234
33
Alliance, Nebraska
Well I can attest that the Carquest filters do not have the correct size seal.
I being stupid and wanting to keep my promise to my son, attempted to reuse the original gasket and I leak like the Exxon Valdez.
