mep-803a coolant temperature sender
cbisson
259
NH
Well for coolant gauges you have a couple options (stock depending). This is a drop in replacement, but will read 15-20* higher than reality (though that has no effect on the coolant overtemp sensor which will still work properly if its too hot)
I have also personally used the DATCON 101587, but I don't see it available anywhere.
The one in the classifieds will work here. If you wanted it to be spot on, I am sure you could get the info from Beede on the resistance range and a suitable sender replacement... but it will work as is.
cbisson
259
NH
There's also this one that appearance wise matches what I bought a couple years ago under the part number (101586) listed above. Has a different part number now....not sure if something changed or if the vendors website is inaccurate.
2Pbfeet
629
Mt. Hamilton, CA
FWIW: The gauges are basically the same, except the 101582 has Fahrenheit and Centigrade, while 101586 is just Fahrenheit.
All the best,
2Pbfeet
