Scoobyshep
- 1,511
- Florida
Tm is technical manual. Theres a few different level of manual for troubleshooting repair and full overhaul.What do you mean by TM's
Sent from my SM-S908U using Tapatalk
That is probably a smart move. You should also fully drain / inspect / clean the tank (and check the seals on the tank), to make sure that there isn't more water in there, and that there isn't a piece of debris in there that could float over and partially block the intake. It would be time well spent in my view. Once you have water in fuel, a lot of ugly things can, and often does, happen, plus there could be gunk leftover from being an old piece of machinery.I have the original pumps someone just put a new separator but I guess I need to replace it again along with the other filter and clean the pumps out.
Okay thanksIf you are needing to update filters, I would strongly suggest swapping out the stock canisters and going with @Ray70's fuel upgrades for the 00X machines. Well worth it for long term owners, and better filtering and EASIER changes!
I tagged him, because Im not sure if they are up in the classifieds or not.
That is probably a smart move. You should also fully drain / inspect / clean the tank (and check the seals on the tank), to make sure that there isn't more water in there, and that there isn't a piece of debris in there that could float over and partially block the intake. It would be time well spent in my view. Once you have water in fuel, a lot of ugly things can, often does, happen, plus gunk leftover from being an old piece of machinery.
All the best,
2Pbfeet
Okay thanks
Okay thanks
Yeah I took the fuel line off at the injector pump and turned it on and pump the gallon out. I had extremely good flow and I noticed it was kind of like a light pink and I thought maybe somebody just mixed clear with red fuel and I tried starting it it always seems to run good when it's cool but when it warms up it starts to smoke and then stops so now I'm thinking that fuel is probably badOkay thanks
Thank you so much yep everything is working took the bottom of the pumps apart clean them put them back and I unhook the fuel line to the injector pump and got very good volume and very good pressure pumped a gallon of fuel out and it looked like kind of pink so I started it and it's the same thing once it kind of warms up then it stops running so I'm going to drain all the fuel out and put new fuel in itThis attachment is not in the TM's. It will help with the pumps. Test them when you have them off the set. Ground the body of the pump on the frame of the gen set and then take a wire and go from the positive side of the batteries, to the wire that is on the pump.
Or, on the machine, unhook all three wires to the pumps. Turn the set on to the run position, but do not start the engine. Take a DMM, (Multimeter) and find what two wires are hot. Hook one pump up. It should begin to pump madly. Unhook it. Then take the wire to the second pump and do the same. Then unhook it. Follow the procedure for the third pump. Make sure all run.
When rehooking them all up, do not worry about what wire to what pump. The two pumps that are hooked to your fuel system, get the two hot wires. The third pump gets the wire left over. Its to the AUX Fuel system, and will only be hot when the start switch is in AUX position.
You need to ask more questions. And dig into the TM's. The only dumb question is the question not asked. And we need to keep in mind to explain more. We, I, have used terms you might not know. So say something.
I believe I've got it figured out I drained the fuel and clean the tank out and check the fuel at the fuel pump and I've got good pressure and good volume and I started it and it ran but I think what's happening is I've got a head gasket leaking bad on the cylinder with the temperature sensor and I believe the temperature sensor it's getting that hot air blown onto that sensor and shutting down it runs for about 6 to 10 minutes and then it just slowly dies. When starting you can see the gasket is leaking pretty bad it's blowing smoke out of that cylinder around the valve cover and the shield. I cannot do a video for some reason.If you are needing to update filters, I would strongly suggest swapping out the stock canisters and going with @Ray70's fuel upgrades for the 00X machines. Well worth it for long term owners, and better filtering and EASIER changes!
I tagged him, because I'm not sure if they are up in the classifieds or not.
Indeed the filter adapters are not currently listed in the Classifieds, I'm terrible at keeping the add up to date! Too many other irons in the fire I suppose!
However there is a link to my original article in my signature and anyone can PM me for additional info if you'd like.
