2Pbfeet
- 1,167
- 93
- Mt. Hamilton, CA
I agree with @kloppk that crank does sound weak. Can you jump this with a strong set of batteries?
Just going to ask two dumb questions for when you get the magnet/cranking issues sorted; did you check to make sure that the pin in the pump engaged the fork in the rack (by checking under the trapezoidal plate), and did you bleed the air out of the fuel system all the way to the injector?
All the best,
2Pbfeet
All the best,
2Pbfeet
