M116A3 Wheel Seal Part replacement
moehos
Fairbanks Alaska
Hi all,
I've had this old trailer for a number of years now and I have strong suspicions that I'm the first owner to do maintenance of any kind since it got surplused out.
I want to grease the wheel bearings, among many other little things but the TM indicates you are supposed to replace the grease seals during this job.
Can anyone point me towards a napa or oreillys friendly part number for the wheel seals?
The TM states the army part number is 12313027, I did find equipmentpartssalespa.net when searching this part number, I'd still prefer to buy new if possible, but if not, what's other folks experience with this outfit?
TIA
Guyfang
24,533
Burgkunstadt, Germany
OK, You got the right part number, but when a part number has a cage code of 19207, that means its a TACOM made up part number. I looked up the NSN and found that there are several alt. part numbers you can try.
NSN: 5330-01-240-8231
PN: 12313027
PN: 472920
PN: AD3135-E1
PN: AD3515-E1
Tech data:
ACCOMMODATED SHAFT DIAMETER2 1/4 INCHES NOMINAL
SEAL WIDTH0 9/25 INCHES MINIMUM AND 39/100 INCHES MAXIMUM
CASE STYLESQUARE
SEALING ELEMENT STYLEANGULAR
MATERIALRUBBER SYNTHETIC SEALING ELEMENT
moehos
Fairbanks Alaska
PN: 12313027
PN: 472920
PN: AD3135-E1
PN: AD3515-E1
Tech data:
CASE STYLESQUARE
Wow! Thank you
