Dearborn adapter woes
Wingnut13
564
Strafford, NH
Hey all,
Ive got one of the Dearborn adapter DPA III Plus units. I’ll put the picture below. But I can’t get it to communicate with a laptop at all. I’ve used two different laptops with different versions of software. Additionally I’ve got two different USB to serial adapters that you need to utilize to make the connection.
power is on in the truck, three of four lights are powered up on the adapter. Again, see picture below. Does anyone have any tricks or suggestions to make this work? It seems I have the right drivers for the USB to serial adapter.
Im not sure what to do next. I’d appreciate some input
GeneralDisorder
5,760
Portland, OR
USB to serial adapters are notoriously difficult to make work for some applications expecting a hardware serial port.. Best to use a laptop with a built in serial port.
Wingnut13
564
Strafford, NH
Understood…. I have three laptops. None of which have a serial port to include an old engineering laptop. That’s running Win 7 ( never connected to the web) and a newer running Win 11.
I do have a MacBook, but would obviously be needing the serial adapter .
Ronmar
7,913
Port angeles wa
What General said, have had issues with some over the years… you said you tried different versions of windows, did you try running any of them in compatibility mode with even earlier versions like windows XP?
Wingnut13
564
Strafford, NH
I hadn’t tried the compatibility mode. I’ll query my local tech guru for that.
Thanks for the suggestions. I’ll see what I can do with that.
I really don’t want to buy another laptop for a dang serial port.
Lostchain
591
Portland, OR
Hey all,
With the ignition to the truck turned on and the DPA hooked to the truck, what does the Dearborn Adapter validator show? Screenshots please
fuzzytoaster
3,468
Fort Worth, Texas
Make sure to try all channel types, you may just have to do process of elimination. I've noticed some trucks like theJ1708 and others J1939 connection. Make sure the dual-link option is unchecked, these trucks don't support that feature.
aw113sgte
1,305
La Crosse, WI
yes, the adaptor validator points to a problem between the PC and the DPA.
did you download and install the “legacy” drivers from the Dearborn website?
Based on what the validator shows, yes it looks like he does.
I have had very good luck with this adapter on various computers and versions (xp, windows 10). Have used it with CAT ET, Allison Doc, Spicer CTIS, ABS The dearborn driver is for 32bit operating systems only, I doubt that's the issue as it shows you have the driver installed.
coachgeo
3,477
North of Cincy OH
With the exception of CTIS they are all paid software so links cannot be posted on the forum.
pretty sure links can be posted. review the rules.... its less an issue that people turned it into. Mostly rule is about auctions (like gov. planet) where people were 1. mentioning them here, creating sometimes unwarranted run up the auction price and 2. to support the sites advertisers who need to auction prices to NOT be run up so they can win, clean it up, resell for profit, stay in business., buy advertising here.
aw113sgte
1,305
La Crosse, WI
Sure, I should have been more clear, some websites post download links to files that are pirated.
