Towbarman
- 4
- 3
- North Little Rock, Ar. U.S.A
I have a 5Ton Wrecker that will not finish stowing. I have checked the hydraulic fluid tank, it's full. Checked to see if I have hydraulic fluid at the cylinder. All good. When I use the controls all of them work properly except for the stowing of the MAST. When I pull the lever outwards you can see the hydraulic hoses jerk with pressure and the engine bogs down a little bit. When applying the lever in no jerking of the hydraulic hose and no bogging down the engine. I was thinking maybe it's a bad solenoid . Any help will be appreicated. Towbarman
