Fuel gauge help
fungusguy
Oregon
I just purchased this vehicle last week with a broken fuel gauge. The previous owner said that he had replaced both the gauge itself and the sending unit. He said that he determined there must be a broken wire somewhere but couldn’t diagnose where.
I cleaned the ground connections behind the gauge panel and on the left engine head. All of the other gauges read properly. Disconnecting this wire I have indicated in blue does nothing. Swapping the positive wire and the negative with other gauges that are known to work also does nothing/no change.
TOBASH
3,488
Brooklyn, NY
I had this problem on my truck and I literally had to swap the positive wire for the negative wire and the negative wire for the positive wire and voilà my gauge worked
Mogman
9,584
Papalote, TX
The sending unit needs two things, a complete path (wire) to the gauge and the sending unit must have a good ground, the tank is plastic.
fungusguy
Oregon
How did you do that exactly? The gauges I have are grounded through their bezel/foundation clip on the rear and if I swap them I think it would send positive to the ground of the other gauges.
Jinx
Buy me a Coke
161
Gainesville, Florida
He didn't swap the ground wire. In your diagram, he swapped the red wire with the blue wire.
