Hmmwv M1114 soft top conversion
ksoto033
florida
Hi there, im trying to install a soft top on am M1114 uparmour 4 man crew just bought it from GP, can the roof side rails for the 2 man soft top truck will fit properly aligned with the 4 man crew soft top if i use 2 set of rails off a 2 man crew truck?
i dont find at decent price the complete side rails for the 4 man crew trucks but already have the front rails from a previous truck, i was thinking on buy another set amd install it in the back.
Maxjeep1
1,918
Las Vegas Nevada
Back rails are longer than the front if I remember. I never could get the 4-man rail to sit flush with the b-pillar. The bottom edge wouldn’t let my rear X-door close properly.
ksoto033
florida
Thanks for the fast response, ill have to bite the bullet and buy the whole set. Thanks
Maxjeep1
1,918
Las Vegas Nevada
Make sure you get oem rails…. I got a set from SECO and they are Chinese or worse. The left and right side didn’t even match up when put back to back. The bow is thinner and smaller also. I thought I was getting oem stuff as it was advertised.
Screwface
23
Jacksonville/Florida
I also have an M1114 that I'm trying to put a soft top on, my only holdout is a c pillar that I'm trying to find in a 100-mile radius. You got any pictures you can post on how it turned out?
Coonass77
179
33
North Carolina
Before and after
coadydepeche101
Georgia
Hi guys, i did the same with the soft top, and i have done a lot of research on the lower part of the B pillar that is riveted to the outside, it is a little wider than the non armored lower part.. the soft doors dont fit (its really tight) so i removed it but i cant find the part number for the original non armored style. any of you seasoned guys have a part number or know where to get them?
coadydepeche101
Georgia
BTW.. im trying to get just the trim piece that the hinge goes on and not the entire panel.. i know i can get those but thats out of my pay grade to get, and install. i may be better off just making one.. thanks
Coonass77
179
33
North Carolina
Not exactly answering your question, but... I've put soft top kits on 4 different m1114's and kept the original riveted-on lower b pillar panel and have yet to have a soft door (front or rear) not fit with them. It's a little tighter than with the other lower b pillar panel, but I've always been able to adjust the doors to where they open and close just fine with no binding or other concerns. Just FYI...
coadydepeche101
Georgia
yea, i agree.. i know i say it does not fit.. but i really meant it didnt fit like i wanted it to. i could masssage the rubber and it would pop in.. and i thought about flap discing the edges so it would grab the sharp corners. i found the "Rabbet assembly" yesterday and ordered them. unlike the M1114 the Rabbit assembly off the unarmored hmmwv isnt riveted down the middle, its a one piece. so it should go on nicely. thanks man.
johndoe007
New England, CT
wanted to update on the b pillar Rabbets, got the 3 piece original ones off, and got these installed. well worth the money. Still got to get the front hinges marked up and riv nutted, but happy with the outcome so far.
Where did you find the parts you needed to make this happen? looks amazing Great job! What parts did you end up removing replacing?
