Cab Latch Rebuild Kit
coachgeo
3,480
North of Cincy OH
as you might guess...... this question has been asked as much as "what oil do I use" . suggest you search first...... BUTTT that said..... since a new choice litterally just arrived on the market. and that might get lost in a search.... untill a month or so ago... there were no parts available for inside the handle. Now there is... Try search for [ Eco Hubs door handle ] those key words are because they fellow who manufactures the Eco Hubs is the fella making the door handle parts.
PS- aftermarket replacments with little work installing are NOT 400 dollars and their is videos online about them... Mike's stuff is still less costly though.
GeneralDisorder
5,813
Portland, OR
Towbarman
14
North Little Rock, Ar. U.S.A
Yes, I was talking about the hydraulic over air cab latch. I looked at the attached photo. That's what I need. Apparently I didn't see the part number for it. If there is a part number, I'd be happy like a pig in mud. Thanks for the information.
coachgeo
3,480
North of Cincy OH
ahhhhhh.. sorry about that... my brain went to door. Did you look at the parts spread sheet?
coachgeo
3,480
North of Cincy OH
Coachgeo
Thanks for the help. I wish I could use the generic o-ring kit, but the o-ring on the piston is a square type. I'll keep looking online or get a hold of other item manager. Towbarman
confused..... the flat sided ring needed is not in the above kits?
BTW- this helps me out too... I got one to rebuild too.
