- 1,504
- 1,169
- TN
I need to re-attach the load sensor air brake valve on my M1088. Anyone have a picture of this mounted that I can use as a reference? Thank you in advance!
Just need a quick picture of how this brake load sensor is mounted. I took the 5th wheel off and am trying to recall where it was mounted. Thank you in advance!I need to re-attach the load sensor air brake valve on my M1088. Anyone have a picture of this mounted that I can use as a reference? Thank you in advance!
That would be correct…@Ronmar , if the adjustment cable were to come loose, it looks like the default condition is max braking to the rear?
Still need a picture of this item mounted, if you can spare the time : )Just need a quick picture of how this brake load sensor is mounted. I took the 5th wheel off and am trying to recall where it was mounted. Thank you in advance!
Thank you!@Reworked LMTV , I just saw this. I'm picking up some overtime today at work, but if you don’t have pictures by 7 tonight I’ll snag some pictures off my 1084 when I get back home.
Thank you very much Godspeed!!@Reworked LMTV , here’s the pictures. The first three are from the back facing forward and the last is from the front looking back.
did a search for 1088 images etc. came across this video at 1:39 there in the rectangle spot that is sunlit, between the chassis rails, right side, you see what I think is the cable going up. Hope this helps.Just need a quick picture of how this brake load sensor is mounted. I took the 5th wheel off and am trying to recall where it was mounted. Thank you in advance!
Anytime, and if those don’t help much and you need any more or ones at any other angle just let me know.Thank you very much Godspeed!!
We already chatted off-line. I don't have the valve in question. It may be the difference between an A0 and A1, or mine was deleted by someone...maybe hit up @ckouba he has a M1088 .
