Rear Transmission mount bolt
j_boucher
104
Virginia
Good eve , I was curious if anyone knows the size of the rear transmission mount bolts seems mine is missing a few.
Keith Knight
1,838
Wauchula, FL
Well if you have to order bolts online and you don’t have a pitch gauge I’m assuming you have digital calipers that display mm. Obviously measure the diameter of the bolt not the hex head then on a bolt that size you should be able to measure the distance from peak to peak on the threads and determine the pitch. Then measure the length not including the head.
