I might be a little crazy – 4,000 mile M1079 recovery Illinois to Alaska
AKPacker
Anchorage, AK
And it begins! I made good progress today, got the ecohubs installed. Tires are next on the list.
Before, during, and after photos:
71DeuceAK
372
Fairbanks, Alaska
Small world, I bought it from Green Valley just south of Peoria.
Not sure, the turn signals/hazards didn't work when I inspected the truck. I didn't have time to fully troubleshoot the cause at the time, but I noticed that the hazard relay wasn't original, so I'm hoping it is a simple relay swap. Would a failed flasher module totally disable the turn signals/hazards?
No kidding? I have a house in Mason City and have an M929A2
AKPacker
Anchorage, AK
Wheels tires, and filters galore! I got all 5 tires mounted and everything went ok except for a couple of spun studs that mount the split rims together. They should be good with the remaining 19 bolts right? Is there a field expedient fix for spun split rim studs?
I got the 3 piece run flats installed on the front wheels. It was a massive pain in the rear to get the run flats and the 2 bead lock rings lined up correctly in the tire so that everything would go on the rim smoothly. Definitely Type-3 fun, I do not recommend doing this solo.
All new engine oil, oil filter, fuel filter, and fuel/water separator were installed. The fuel/water separator on the C7 is hard to change without getting diesel everywhere.
Tomorrow I've got a few minor things to finish up, grease points, and the desiccant cartridge, then hopefully it'll be time to hit the road!
IMG_20240604_100630947.jpgIMG_20240605_103817207.jpgIMG_20240605_205012360.jpgIMG_20240605_181408837.jpgIMG_20240605_202823743.jpg
coachgeo
3,392
North of Cincy OH
Is the black part in above pic what you had real hard time keeping aligned to fit the outer rim bead rings on?
AKPacker
Anchorage, AK
Well, I made it as far as Spearfish South Dakota, I'll write more about the journey later. I've developed some pretty severe wheel hop on the front axle. I'm going to try to find a truck shop to get the front end checked out, but might not have much luck on a Sunday. Any troubleshooting ideas/suggestions in the mean time?
GeneralDisorder
4,469
Portland, OR
Wheel hop? Can you take a video? Not sure what you are describing. Vibration? Is it speed dependent?
AKPacker
Anchorage, AK
To update this, the truck is running amazingly besides the wheel balance issues I posted about in another thread. I'm currently in BC Canada with limited internet service. I've driven bout 2500 miles so far, the ecohubs are awesome, I got approximately 10 mpg going through the mountains from Alberta to BC yesterday.
tennmogger
539
Greenback, TN
Wheel bounce is probably due to out of round tires. Common with the tires I have tried, sadly. No solution that I know of other than slow down or get the tires trued. Balance beads do not help.
Moving the worse tire to the rear might help.
ab705
62
13
Maine
How about tire shaving/truing? If they aren't too far out-of-round, you shouldn't lose too much tread depth.
GeneralDisorder
4,469
Portland, OR
If you just drive the truck regularly they will true up on their own. Also having a working CTIS system with the wiring mod for multiple highway pressure settings or manual control is VERY useful. You can simply drive the speed you want and alter the tire pressure dynamically while you are driving till you find a pressure at which your desired speed has the least vibration.
Mrgior31513
96
Fontana, Ca
Just wanted to say, the amount of planning, work and effort that you've put into trying to make this happen is just inspiring and awesome. I can't add much to your current endeavor, except some encouragement in that I think your current journey is pretty impressive. I've seen a lot of people take risks and try to make things happen, but the level of planning and work accompanying it is where it's at.
