Humvee Engine Knocking (yes it's actual knocking, probably)
Mogman
10,142
Papalote, TX
As an explanation of Mogman post, you keep cracking injector fuel lines until you find the one that does not affect the cadence/tap. The bad injector line can’t push fuel through so loosening it can’t affect the engine rhythm.
Not exactly, if an injector it is leaking which causes the cylinder to fire early creating a knock, you crack the lines one at a time until the knock stops, then you have found the defective injector.
TOBASH
3,829
Brooklyn, NY
Respectfully. Not all injectors get stuck OPEN. This method I described is exactly how I found a plugged/closed injector that needed replacement.
Hmmwvben
New Jersey
I tried that without much success. The 400 amp alternator makes it impossible to reach cylinders 1 and 3 without removing it. I cracked all the others but its hard to isolate where the noise is coming from. The noise is very quiet when first starting at idle, goes in and out when driving, and was temporarily fixed with a bottle of Seafoam in the fuel filter when I changed it.
TOBASH
3,829
Brooklyn, NY
Loosen the injector hoses from underneath. Crawl under. Trust me.
Mogman
10,142
Papalote, TX
Can you get the the IP end of the injector lines for 1-3?
Northcross
AZ
hello. I’m replying to the original post because I’m having a similar problem. After running for months without any problems the engine started to make a knocking noise and spitting out a lot smoke. The video below shows the knocking. This engine was replaced 20 months ago and I only drove from 4500 miles. Any suggestions what to check? From the original post some people mentioned injectors, lifter, change oil, etc.
Appreciate any suggestions.
Mine was making similar noise. Knock became quicker at RPM, blew a white cloud of smoke then lost power and wouldn’t start again.
Mogman
10,142
Papalote, TX
Again check all you fluids, it sounds like your transmission is slipping badly.
derrickthompson83
Fellsmere, Florida
Hello fine individuals, I started hearing some noises today that nobody likes to just start hearing out of the blue.
Basically, I've had this M1043A2 6.5L for almost a month, been getting it fixed up while waiting for the sf97 to come in. Today, I installed a new oil pressure and voltage gauge, as the previous ones had water intrusion. I take it out for a drive, and I'm about 20 minutes in with the engine at full operating temperature. As I'm driving at around 35-40MPH, I start hearing a very audible clacking/smacking sound, very different than anything I've heard from this machine yet.
I pull over and shut it off and then proceed to look around the engine bay for anything loose, the only thing I found was that the crankshaft pulley has a little bit of play in the rubber. I start it again and rev it slowly a few times. The clacking follows the engine RPM, and is 100% not part of the normal diesel clacking sounds you typically encounter.
So far.. I've read that it can be a few things:
1: Bad injector
2: Cracked piston / head
3: Loose pulleys / bad bearings
4: Other fun things
Trying to narrow down what it is, I took a video and the sound is very evident around the 30-40 second mark:
If anyone's heard this before or has any ideas on what I can check, would be appreciated. One thing of note is that my bottom-most injector line on the injection pump is pretty rusted, so there may be a possibility of air getting in the line? But it doesn't seem to be leaking either. I'll probably start by pulling the injector lines one-by-one and seeing if the noise persists.
What did you ever find caused the knocking noise ?
googan
Atlanta
Alright so… update on the situation:
I changed the oil and filter yesterday, per the immediate recommendation of some of you. drove it around several times, getting it up to full temp each time. Didn’t hear the knocking the whole day. Now I’m gonna sit here and hope I don’t hear it again.
I shall tuck this knowledge away for future reference, thank you all for your inputs. I’ll monitor this over the next week and hopefully the stick banging gremlins stay at bay.
Does your engine still sound good? I have the same noise. I’ll be running a flush through it and changing the oil this weekend. 🤞
biscuitwhistler37
1,109
Michigan
General tip, lifters "tick" when they don't get enough lubricity, thin oil does not offer enough lubricity. Old oil may be thick to start, but thins very quickly as it warms, and may as well be water when it gets hot, note how the ticking gets louder as the engine gets warmer.
Hydraulic lifters, like found in the 6.5, RELY on correct viscosity oil to function, thin oil equals lazy, sticky, not having a good time lifters.
This is why (among other reasons, like contaminants) the experts recommend changing the engine oil FIRST.
Mogman
10,142
Papalote, TX
I am not a big fan of changing the oil on an engine that has sat for a long time, as long as the oil looks OK I pull the plug just long enough to ensure there is no water or other funny stuff in there (then top it off a little over full to help the pump prime), then I start the engine for a couple minutes, this will get oil to the bearings much faster than if you change the oil and have to first pick up the oil and then fill the filter. After a couple minutes I then change the oil.
I have found if the oil looks "bad" there are usually other problems....
Just my two cents :)
frauhansen
570
switzerland
I your affraid about the bearings, than disconnect the fuel pump wire and the glow plug connector. Then turn the engine over.
The engine will only driven by the starter. No load on the bearings cause no ignition in the zylinders.
So you can start with no fear after a oelchange or if you dont know how good the oelpressure is.
