M1009 Motor Mounts
CSandoz
30
Lafayette Louisiana
Good Morning all.
Whilst crawling around under my rig this weekend i noticed that my passenger side motor mount is all but wiped out.
Naturally i dove into the rabbit hole of CUCV Motor mounts. :rolleyes:
After reading many of the threads here on the subject, the "kit" that seems most popular is the Energy Suspension 3.1124G.
For those of you running this part number, have you run into any issues? How has the clearance been over time?
My aim is to have to swap these out one time and not several times. I'm basically looking to verify the information.
Thanks in advance.
WWRD99
1,664
York Pa
Yes we've used them on all so far and no real problems at all. Only thing that we got was severe vibrations going into the cab...gotta leave the bolts loose and run the engine to let it find it's happy spot in the bay. That one we did the trans mounts at the same time and was a little twisted in the mounts so it would vibrate the dash out. Simple fix but only real problem. Takes about an hour with a basic cherry picker lifting the drivers side only...can do both side from the one lifting point.
CSandoz
30
Lafayette Louisiana
Yes we've used them on all so far and no real problems at all. Only thing that we got was severe vibrations going into the cab...gotta leave the bolts loose and run the engine to let it find it's happy spot I'm the bay. That one we did the trans mounts at the same time and was a little twisted in the mounts so it would vibrate the dash out. Simple fix but only real problem. Takes about an hour with a basic cherry picker lifting the drivers side only...can do both side from the one lifting point.
That's good info to know. I appreciate the intel.
If i might ask, did you also replace your Mounting bolts? or did you just clean them up and re-use them?
i was thinking about replacing the grade 5 (3/8-16) bolts that hold the clam shells down.
I noticed also in the TM's that the driver side and passenger side linking bolts ( 7/16-14 ) were not the same. apparently each side has a different bolt?
WWRD99
1,664
York Pa
No we used all the original stuff in there with a few exceptions if someone was in there before and used weird stuff. Like to have the same bolt head size and not a mismatch. The passenger side main bolt goes through a cutout in the mount so it can be put in without taking the starter out.
CSandoz
30
Lafayette Louisiana
Just an update. Changed the motor mounts and transmission mounts on this 4th of July weekend. The energy suspension kit I ordered fit like a glove. My passenger side motor mount literally fell apart in my hand when I took it out, so it definitely needed it. Transmission mounts were equally nice. Now to hunt for a quality replacement for the lift pump that was laying on my frame for so long. I think the new mounts raised the motor a good 5/8" on each side. They were pretty bad. Thank you all for the Intel that led to a successful mission! 😀
