Possible bad alternator
j_boucher
103
Virginia
So I noticed my voltage was a the bottom of the 28V on my gauge, I went and check the alternator out put and they seemed fine but was curious does the voltage regulator lights blinking on and off green normal or do they need to be steady , no other colors just green , I just took it to the store and noticed my headlight symbol in dash blinking and when I got home I noticed the front lights turning on and off corresponding with the dash light. And now I have no more output from the alternator regulator lights still blinking . Anyone ever seen this ?
MatthewWBailey
Father, Husband and Barn Hermit
1,409
Mesa, Colorado
Ronmar
7,250
Port angeles wa
Thanks I believe it was the grounding strap I cleaned connections on grounding strap, Both 28V and 14V wires and terminals at battery . Seems to be working OK. Thanks for the quick responses greatly appreciated
Have you cleaned the connections on the polarity box/LBCD back by the spare tire? How about ground strap between starter and drivers frame? the alt relies on a good connection between alt and batt, all 3 of them, 12, 24 and gnd…
j_boucher
103
Virginia
Those are on the list today , although I don't remember ever seeing one on the starter will be going out to check soon
Ronmar
7,250
Port angeles wa
The battery ground lead cable runs to a stud on the front of the starter motor housing. From that stud there is a braided strap over to the drivers frame rail. That is how battery ground reaches the rest of the chassis…
voltage drop tests can be run on all these circuits if you have a battery load tester. the voltage dropped/developed by the wire resistance while feeding a load thru the circuit is a definitive test of circuit capability…
j_boucher
103
Virginia
Yes I found it , already cleaned the connections on the polarity box , curious when the change from being the Polarity relay box went to being the newer LBCD .
j_boucher
103
Virginia
The battery ground lead cable runs to a stud on the front of the starter motor housing. From that stud there is a braided strap over to the drivers frame rail. That is how battery ground reaches the rest of the chassis… ------ Mine has a good amount of rtv type substance on the front of starter " prob for water proof" , beginning to clean all this now
Ronmar
7,250
Port angeles wa
In place of a rubber cover, the rtv keeps a dropped wrench from arc welding itself in place. Not needed on the ground stud though, only the + terminals on the solenoids and starter motor…
later A1 trucks added the battery disconnect relay and the LBCD to control it/ disconnect the load/batts from an overloaded alt and put them on a trickle charge.
I believe this was a bandaid to protect the alt from the grossly oversized battery instead of upsizing the alt to match the batts. AGM batts made the problem too big to hide with a LBCD, so they finally upsized the alt to a proper size for the batts…
Skyhawk13205
253
Alaska
it is common to have potting on ground and bonding straps in the aviation world, usually the potting you use is a special type of RTV that is less corrosive, what the potting does best is to hold the water and corrosion in until the connection fails, usually intermittently and at the worst times possible.
Ronmar
7,250
Port angeles wa
Exactly! I have never seen topically applied RTV seal anything, except the moisture inside the connection:)
