Enforced_Leo44
- 76
- 28
- Parma, Italy
Hi everyone,
M1008 owner here, just noticed a pretty annoying oil leak on the passenger side of the aluminum oil cooler lines that run across the radiator, behind the fan shroud, I still have to determine which one is leaking (if not both).
Looked around the internet to find a pair to buy and soon found out that they are quite expensive (around 200$ on hillbilly wizard).
And the first question that pops up is: do I have to replace them with a OEM part or can I go with a pair or oil resistant rubber lines with steel fittings? That sounds a whole lot cheaper, but I guess that there is a reason for them being made out of aluminum and not some good ole rubber.
Any suggestion/shared experience would be greatly appreciated, thanks in advance,
Leo
Leo
