change old hydraulic -> new hydraulic pump/system
frauhansen
538
switzerland
Hi everyone
As I'm thinking of replacing my servo pump, I thought to myself... why not switch to the new system? So from the pump with the reservoir integrated to the new one with the reservoir on the top left.
As I have never seen the newer system, I don't know exactly what the differences are.
Is it enough to buy the pump and reservoir? The hoses are certainly different, but you can organize that when it's in front of you.
Possibly any other holders?
Does anyone know anything more specific?
Retiredwarhorses
4,137
Brentwood, Calif
The entire serpentine system has to be upgraded as well as the belt and pulley on the generator…it’s not a cheap conversion.
but if you insist? I probably have everything
frauhansen
538
switzerland
Am I right in assuming that you think I still have the old V-belt system?
No no, in mine, and I think in every 1123, the separate belt system should be standard.
Retiredwarhorses
4,137
Brentwood, Calif
No, I’m not assuming…if you don’t have the later style serp setup, you can’t install the new style pump and remote reservoir.
I recommend a trip to the parts TM
frauhansen
538
switzerland
Okay... got it.
Trying to understand what the difference is. I would have assumed it was the brakket for holding the pump. Okay... that could have a much bigger impact.
