Leak in rear righthand brake caliper
Enforced_Leo44
75
Parma, Italy
As the title says, my rear righthand brake caliper started to leak, vehicle is a 1988 M998, which means I already have the "dual purpose" rear caliper, that function as service AND parking brake
I looked around, there are a couple of rebuild kit that include all the little internal seals, specific for my kind of Humvee caliper, they sell for around 80$
There are also kits that only include the piston boot and the square cut seal that goes into the housing around the piston, which would cost way less and I think that I'd only need those because the leak comes from the piston itself, but I don't know if those are only for the front calipers
Which brings us to my question: are the boots and square cut seals for front and rear caliper identical/interchangeable or are those different from front to rear?
FFesco
New York
I’m having the same exact issue. May just get a new caliper, I did read somewhere on these forums of a cheaper alternative like American eagle vehicle, something along those lines
TOBASH
3,369
Brooklyn, NY
FRONT calipers are American Eagle. Rear are NOT. Rear cost $$$.
Coug
4,241
Olympia/WA
depending on what the leak is from, you may be able to get a repair kit for it and do the rebuild yourself. Not all that complicated if you're halfway decent at following instructions or are mechanically inclined. I think the rebuild kits are in the $50 or so range, where the entire caliper was over $300 or so last I checked (when I rebuilt my own rear caliper due to a sticking parking brake)
